[GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
Michael Barton michael.barton at asu.edu
Wed Aug 16 02:13:54 EDT 2006
I can confirm this. There seems no way to satify g.region. We've set the
WIND file manually and still get the same error.
We did a make distclean and recompiled today (15 August) and still have the
same results. This is on an FC4 32bit system.
I tried the identical actions on my Mac, using 6.1.0 binaries compiled 12
August and had no trouble at all.
Did something change with g.region? Could this be due to the parser changes
that Markus mentioned earlier today?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Isaac Ullah <isaac.ullah at asu.edu>
> Date: Tue, 15 Aug 2006 18:07:09 +0000
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
> Hi all,
>       A very interesting and frustrating problem has just presented
> itself to me. The region settings seem to "break" after using the new
> zoom tools from the map display. i get the following error message in
> the Output window:
> region for current mapset is invalid
> line 15: <depths:     0>
> run "g.region"
>     This message displays after zooming a few times, or after attempting
> to do anything at all with "g.region" (including just printing region
> settings). Also, all the new zoom tools in the map display seem to do
> nothing after this message, and I cannot display any of the maps in my
> mapset. I have looked at the WIND file for the afflicted mapsets, and
> they seem perfectly normal. For example, the above error message is
> associated with the following WIND file:
> proj:       1
> zone:       36
> north:      3742844.70455
> south:      3309044.70455
> east:       944264.754065
> west:       560076.932184
> cols:       12806
> rows:       14460
> e-w resol:  30.0006108
> n-s resol:  30
> top:        1
> bottom:     0
> cols3:      12806
> rows3:      14460
> depths:     1
> e-w resol3: 30.0006108
> n-s resol3: 30
> t-b resol:  1
>  Making a new mapset allows me to run "g.region" without any problems
> until I use the new zooming tools, and then the same problem occurs.
> Restarting GRASS initially allows for the maps to be displayed again,
> but after zooming a bit, or trying to run "g.region" again, the region
> eventually "breaks" again. What I specifically do not understand is why
> the error tells me to run "g.region" when doing so does nothing, and
> seems to even cause the error in the first place. Does anybody have any
> idea what the issue is here? I am using GRASS 6.3, compiled from the CVS
> source yesterday (08/15)... Any help would be greatly appreciated.
> Cheers,
> Isaac
