[GRASS-dev] [bug #5017] (grass) cannot identify the pg database driver
Request Tracker grass-bugs at intevation.de
Thu Aug 17 12:59:12 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5017
Subject: cannot identify the pg database driver
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 6.3 CVS, 2006_08_12
If I tried to load vectors in nviz, v.overlay and g.remove it could not connect to the PostgreSQL datasource, got the following error report:
dbname=DB_danube_basin,: no such driver available
GRASS_INFO_WARNING(16345,1): Cannot open driver 'dbname=DB_danube_basin,'
GRASS_INFO_ERROR(16345,2): Cannot open database host=192.168.142.1, by driver dbname=DB_danube_basin,
It apparently messing up the driver's name with the database name. However, the db.connect, dv.login, d.vect are working fine.
Regards
Tomas Lanczos
Dept. geochemistry
Commennius University, Bratislava
Slovakia
-------------------------------------------- Managed by Request Tracker
