[GRASS-dev] [bug #5042] (grass) v.digit: Settings pop-up off the screen
Request Tracker grass-bugs at intevation.de
Wed Aug 23 14:51:48 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5042
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=305247
> On a 800x600 monitor, the Settings pop-up window comes up always
> partially off the screen and has to be manually moved back.
> Besides, the rightmost main menu Exit button is also half cut off.
Does this refer to placement or the the windows size?
GRASS is not doing placement.
I assume that you mean size: in fact the window exceeds
800 pixels in widths which should be somehow fixed (smaller
icons?).
cc GRASS bugtracker.
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
--- Headers Follow ---
>From neteler at itc.it  Wed Aug 23 20:51:48 2006
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from kolab.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id D02241005DA
	for <grass-bugs at lists.intevation.de>; Wed, 23 Aug 2006 20:51:48 +0200 (CEST)
Received: from localhost (localhost.localdomain [127.0.0.1])
	by kolab.intevation.de (Postfix) with ESMTP id B7597194464
	by kolab.intevation.de (Postfix) with ESMTP id 75992194217
Received: from mail.itc.it (unknown [217.77.80.3])
	by kolab.intevation.de (Postfix) with ESMTP id 33C8D193D7D
	for <grass-bugs at intevation.de>; Wed, 23 Aug 2006 20:51:46 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
	by mail.itc.it (8.12.11.20060308/8.12.11) with ESMTP id k7NIpSls015693;
	Wed, 23 Aug 2006 20:51:30 +0200
Received: from bartok.itc.it. (bartok [10.40.0.190])
	by orchestra.itc.it (8.12.11.20060308/8.12.11) with ESMTP id k7NHhFXi031856;
	Wed, 23 Aug 2006 19:43:15 +0200
Received: from bartok.itc.it. (localhost.localdomain [127.0.0.1])
	by bartok.itc.it. (8.13.1/8.13.1) with ESMTP id k7NHhFaW014444;
Received: (from neteler at localhost)
	by bartok.itc.it. (8.13.1/8.13.1/Submit) id k7NHhFp9014443;
Date: Wed, 23 Aug 2006 19:43:15 +0200
To: 305247 at bugs.debian.org
Cc: grass-bugs at intevation.de
Subject: v.digit: Settings pop-up off the screen
Message-ID: <20060823174315.GG14363 at bartok.itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.4.1i
X-PGP-Key: http://www.gdf-hannover.de/neteler/markus_gpgkey.asc
X-PGP-Fingerprint: D4D5 2F80 120E AD60 E2F6  2297 21B3 D02B E1E7 E789
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=-4.241 tagged_above=-999 required=3 tests=[AWL=0.759,
 BAYES_00=-5]
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
