[GRASS-dev] [bug #5042] (grass) v.digit: Settings pop-up off the screen
Michael Barton michael.barton at asu.edu
Thu Aug 24 16:55:42 EDT 2006
I just did this and committed it to the CVS.
I also did a few other minor cosmetic improvements. I wanted to do a few
more, but the values going into the form are coming from the C code.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Thu, 24 Aug 2006 14:48:34 +1200
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: <305247 at bugs.debian.org>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] [bug #5042] (grass) v.digit: Settings pop-up off the
> screen
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=5042
>> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=305247
>>> On a 800x600 monitor, the Settings pop-up window comes up always
>>> partially off the screen and has to be manually moved back.
>>> Besides, the rightmost main menu Exit button is also half cut off.
>> Does this refer to placement or the the windows size?
>> GRASS is not doing placement.
>> I assume that you mean size: in fact the window exceeds
>> 800 pixels in widths which should be somehow fixed (smaller
>> icons?).
>> cc GRASS bugtracker.
> xwininfo show the window has:
>   Width: 813
>   Height: 146
> So we don't need much.
> There are 22 icons across, most are 32x32. Some are smaller, e.g.
> zoom.*.gif. Most could be cropped or edited to 30x30 without much
> damage.
> Alternate, maybe better: move first 11 icons below last 11 (natural
> break there), this results in a 2x11 block of icons.
> It's set at line 76 of vector/v.digit/toolbox.tcl, but I don't know
> enough tcl to make it into two rows. help?
> Hamish
