[GRASS-dev] creating new modules
Yann Chemin ychemin at gmail.com
Tue Aug 29 07:50:08 EDT 2006
Hi Kirk,
can you tell me where i can read about your model and if you have a
flow-chart of the main module in its actual .CPP form.
This kind of model is interesting for our research in University,
therefore i would be happy to help for the porting in GRASS GIS.
sincerely,
Yann
On 04/08/06, Kirk R. Wythers <kwythers at umn.edu> wrote:
> I am interested in porting an ecosystem model (carbon balance model) to a
> grass module. Currently my simulation model consists of 4 .cpp files
> (essentially a "main" file, a vegetation parameters file, and climate file,
> and a io file), and then 3 associated header files. I found the link:
> http://grass.itc.it/intro/modelintegration.html
> Which describes simulation models that have been incorporated into grass.
> But could also use some general advice as to "best practices" new module
> structure. Has anyone put together a grass module howto? Perhaps the
> programmers guide? I've been digging around on the wiki, but haven't found
> what I'm looking for yet. What I am basically asking for is to be pointed to
> a well done example that I should follow as "simulation model module
> template"
> Any suggestions?
> Thanks,
> Kirk
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
