[GRASS-dev] grass63 -text startup screen
Trevor Wiens twiens at interbaun.com
Wed Aug 30 09:56:09 EDT 2006
On Wed, 30 Aug 2006 15:24:12 +0200
Maciej Sieczka <tutey at o2.pl> wrote:
> Hi,
> Grass text startup screen says:
> LOCATION: This is the name of an available geographic location.
> -spearfish- is the sample data base for which all tutorials are written.
> This is not true and incomplete. How do I correct it? I suggest:
> LOCATION: This is the name of an available Grass location
> (data set). "spearfish" is the sample data set for which many
> tutorials are written. You can obtain it at http://grass.itc.it.
> OK?
FWIW, your changes sound good to me. Carefully planned language use
very important.
> Maciek
> P.S.
> http://grass.itc.it/download/data.php contains:
> GRASS locations (databases)
> Let's not mix location and database. I think it could be:
> GRASS locations (data sets)
> instead.
Definitely. We don't need another "layers" issue.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
