[GRASS-dev] configuring grass 6.3 for cross compilation
Fri Dec 1 19:00:47 EST 2006
Benjamin Ducke wrote:
> I am trying to cross-compile GRASS 6.3.cvs using Radim's instructions
> on this page: http://wiki.qgis.org/qgiswiki/BuildingWindowsBinaryOnLinux
> However, configure aborts with:
> checking for proj_api.h... yes
> configure: warning: *** Cannot check PROJ.4 version (cross-compiling).
> checking for location of External PROJ.4 library...
> checking for pj_get_def in -lproj... yes
> checking for location of External PROJ.4 data files...
> configure: warning: *** External PROJ.4 directory not specified
> checking for /epsg... configure: error: Cannot check for file existence
> when cross compiling
> This did not happen with a 6.1 cvs version.
> Are there any updates on how to configure 6.3 for cross compilation?
> Any help will be greatly appreciated!
Right now, you can't. I'm looking into a fix, but until then you'll
need to manually remove the check from the configure script.
