[GRASS-dev] implementing drop column into DBF driver
Markus Neteler neteler at itc.it
Mon Dec 4 11:33:27 EST 2006
I tried to implement drop column into DBF driver to get
rid of columns like 'cat_' when re-importing an exported map:
echo "ALTER TABLE mymap DROP COLUMN cat_" | db.execute
Attached the changes to lib/db/sqlp/ and /db/drivers/dbf/
The idea is to load the table internally in SQLP_DROP_COLUMN
(such as SQLP_ADD_COLUMN does) but to jump over the column
which we want to drop.
So I took load_table() and made it load_table_selective(),
most likely in an ugly way.
While ugly, it could work but apparently I never reach
SQLP_DROP_COLUMN. It bails out with
D3/3: sql: ALTER TABLE mymap DROP COLUMN cat_
D3/3: SQL statement parsed successfully: ALTER TABLE mymap DROP COLUMN cat_
D3/3: add_column(): tab = 11, type = 3, name = edg_id, width = 20, decimals = 6
D3/3: Doing SQL command <8> on DBF table... (see include/sqlp.h)
dbmi: Protocol error
D2/3: G__home home = /home/neteler
ERROR: Error while executing: "ALTER TABLE mymap DROP COLUMN cat_
I have no clue why. Help is welcome.
Thanks,
Markus
? include/config.h
? include/version.h
? include/winname.h
? include/Make/Grass.make
? include/Make/Platform.make
? lib/db/dbmi_base/OBJ.i686-pc-linux-gnu
? lib/db/dbmi_client/OBJ.i686-pc-linux-gnu
? lib/db/dbmi_driver/OBJ.i686-pc-linux-gnu
? lib/db/sqlp/OBJ.i686-pc-linux-gnu
? lib/db/sqlp/lex.yy.c
? lib/db/sqlp/y.output
? lib/db/sqlp/y.tab.c
? lib/db/sqlp/y.tab.h
? lib/db/stubs/OBJ.i686-pc-linux-gnu
Index: include/sqlp.h
RCS file: /home/grass/grassrepository/grass6/include/sqlp.h,v
retrieving revision 1.18
diff -u -r1.18 sqlp.h
--- include/sqlp.h	10 Oct 2006 08:21:34 -0000	1.18
+++ include/sqlp.h	4 Dec 2006 16:14:10 -0000
@@ -10,6 +10,7 @@
 #define SQLP_UPDATE 5
 #define SQLP_DELETE 6
 #define SQLP_ADD_COLUMN 7
+#define SQLP_DROP_COLUMN 8
 /* SQL OPERATORS */
   /* Arithmetical */
Index: lib/db/sqlp/print.c
RCS file: /home/grass/grassrepository/grass6/lib/db/sqlp/print.c,v
retrieving revision 1.12
diff -u -r1.12 print.c
--- lib/db/sqlp/print.c	10 Oct 2006 08:19:34 -0000	1.12
+++ lib/db/sqlp/print.c	4 Dec 2006 16:14:10 -0000
@@ -75,6 +75,9 @@
 	case (SQLP_DROP):
             fprintf( stderr, "DROP\n");
 	    break;
+	case (SQLP_DROP_COLUMN):
+            fprintf( stderr, "DROP COLUMN\n");
+	    break;
 	case (SQLP_INSERT):
             fprintf( stderr, "INSERT\n");
 	    break;
Index: lib/db/sqlp/yac.y
RCS file: /home/grass/grassrepository/grass6/lib/db/sqlp/yac.y,v
retrieving revision 1.24
diff -u -r1.24 yac.y
--- lib/db/sqlp/yac.y	10 Oct 2006 08:19:34 -0000	1.24
+++ lib/db/sqlp/yac.y	4 Dec 2006 16:14:11 -0000
@@ -104,6 +104,8 @@
 y_alter:
 		ALTER TABLE y_table ADD COLUMN y_columndef	{ sqpCommand(SQLP_ADD_COLUMN); }
 	|	ALTER TABLE y_table ADD y_columndef		{ sqpCommand(SQLP_ADD_COLUMN); }
+	|	ALTER TABLE y_table DROP COLUMN y_column	{ sqpCommand(SQLP_DROP_COLUMN); }
 y_create:
? db/drivers/dbf/OBJ.i686-pc-linux-gnu
Index: db/drivers/dbf/dbfexe.c
RCS file: /home/grass/grassrepository/grass6/db/drivers/dbf/dbfexe.c,v
retrieving revision 1.38
diff -u -r1.38 dbfexe.c
--- db/drivers/dbf/dbfexe.c	10 Oct 2006 08:20:25 -0000	1.38
+++ db/drivers/dbf/dbfexe.c	4 Dec 2006 16:25:39 -0000
@@ -70,7 +70,7 @@
     G_free ( tmpsql) ;
-    G_debug (3, "SQL statement parsed successfully" );
+    G_debug (3, "SQL statement parsed successfully: %s", sql );
     /* sqpPrintStmt(st); */ /* debug output only */
@@ -91,7 +91,8 @@
     if ((st->command == SQLP_DROP) || (st->command == SQLP_DELETE) ||
-        (st->command == SQLP_INSERT) || (st->command == SQLP_UPDATE) || (st->command == SQLP_ADD_COLUMN)
+        (st->command == SQLP_INSERT) || (st->command == SQLP_UPDATE) ||
+       	(st->command == SQLP_ADD_COLUMN) || (st->command == SQLP_DROP_COLUMN)
 	if ( db.tables[tab].write == FALSE ) {
   	    append_error( "Cannot modify table, don't have write permission for DBF file.\n");
@@ -102,7 +103,7 @@
     /* find columns */
     ncols = st->nCol;
     if (st->command == SQLP_INSERT || st->command == SQLP_SELECT
-	|| st->command == SQLP_UPDATE) {
+	|| st->command == SQLP_UPDATE || st->command == SQLP_DROP_COLUMN) {
 	if (ncols > 0) {	/* colums were specified */
 	    cols = (int *) G_malloc (ncols * sizeof(int));
 	    for (i = 0; i < ncols; i++) {
@@ -140,6 +141,7 @@
     /* do command */
+    G_debug(3,"Doing SQL command <%d> on DBF table... (see include/sqlp.h)", st->command);
     switch (st->command) {
     case (SQLP_ADD_COLUMN):
 	load_table(tab);
@@ -159,6 +161,15 @@
 	    dbval->d = 0.0;
 	    dbval->c = NULL;
 	    dbval->is_null = 1;
+	db.tables[tab].updated = TRUE;
+	break;
+	ret = load_table_selective(tab, st->Col[0].s);
+	if ( ret == DB_FAILED ) {
+	    append_error("Cannot delete column.\n");
+	    return DB_FAILED;
 	break;
Index: db/drivers/dbf/proto.h
RCS file: /home/grass/grassrepository/grass6/db/drivers/dbf/proto.h,v
retrieving revision 1.4
diff -u -r1.4 proto.h
--- db/drivers/dbf/proto.h	16 Mar 2004 13:06:33 -0000	1.4
+++ db/drivers/dbf/proto.h	4 Dec 2006 16:25:39 -0000
@@ -17,6 +17,7 @@
 int free_table ( int );
 int find_table ( char * );
 int load_table_head( int );
+int load_table_selective ( int, char *);
 int load_table( int );
 int save_table( int );
 int describe_table( int, int *, int, dbTable ** );
Index: db/drivers/dbf/table.c
RCS file: /home/grass/grassrepository/grass6/db/drivers/dbf/table.c,v
diff -u -r1.18 table.c
--- db/drivers/dbf/table.c	9 Feb 2006 03:08:48 -0000	1.18
+++ db/drivers/dbf/table.c	4 Dec 2006 16:25:39 -0000
@@ -216,6 +216,78 @@
     return DB_OK;
+/* loads table except for dropcol */
+int
+load_table_selective ( int t, char *dropcol)
+    int  i, j, ncols, nrows, dbfcol;
+    DBFHandle   dbf;
+    char *buf;
+    ROW  *rows;
+    VALUE *val;
+    G_debug ( 3, "load_table_selective(): tab = %d  dropcol = %s", t, dropcol);
+    if ( db.tables[t].loaded == TRUE ) /*already loaded */
+        return DB_OK;
+    dbf = DBFOpen( db.tables[t].file, "r" );
+    if( dbf == NULL ) {
+	append_error("Cannot open dbf file.\n");
+        return DB_FAILED;
+    ncols = db.tables[t].ncols;
+    nrows = DBFGetRecordCount( dbf );
+    rows = db.tables[t].rows;
+    rows = (ROW *) G_malloc ( nrows * sizeof(ROW) );
+    db.tables[t].arows = nrows;
+    G_debug ( 2, "  ncols = %d nrows = %d", ncols, nrows);
+    for( i = 0; i < nrows; i++ )
+         rows[i].alive = TRUE;
+         rows[i].values = (VALUE *) G_calloc ( ncols, sizeof (VALUE) );
+         for( j = 0; j < ncols; j++ )
+	     /* jump over column to drop */
+             if ( G_strcasecmp( db.tables[t].cols[j].name, dropcol ) == 0 )
+	     	continue;
+	     val = &(rows[i].values[j]);
+	     dbfcol = j;
+	     val->is_null = DBFIsAttributeNULL ( dbf, i, dbfcol );
+	     if ( !(val->is_null) ) {
+		 switch ( db.tables[t].cols[j].type )
+		     case DBF_INT:
+			 val->i = DBFReadIntegerAttribute( dbf, i, dbfcol );
+			 break;
+		     case DBF_CHAR:
+			 buf = (char *) DBFReadStringAttribute( dbf, i, dbfcol );
+			 save_string ( val, buf);
+			 break;
+		     case DBF_DOUBLE:
+			 val->d = DBFReadDoubleAttribute( dbf, i, dbfcol );
+			 break;
+    DBFClose ( dbf );
+    db.tables[t].rows = rows;
+    db.tables[t].nrows = nrows -1; /* one less */
+    db.tables[t].loaded = TRUE;
+    return DB_OK;
 int
 save_table ( int t)
