[GRASS-dev] Re: v.in.gpsbabel bug? (with es file)
Davide Spano spano at cli.di.unipi.it
Tue Dec 5 03:45:35 EST 2006
Il giorno lun, 04/12/2006 alle 16.26 +0100, Leonardo Lami ha scritto:
>  Hi all,
>  I'm testing v.in.gpsbabel but I found a not corrspondence between tha datas
>  associated to the point in gps and the datas associated to the new vector.
> If I use a gps Garmin 12 (not Etrex) the label associated to the points
> (second column in the file
>  gps.csv, download by gpstrans) is not present in the table associated to
>  the vector (gpsbabel.dbf).
> If I use gps Garmin 12 Etrex it works well (gpsbabel_etrex.dbf).
>  Does someone know this bug?
>  Thank you for help
>  Regards
>  Leonardo
Hi all,
I think that the field is not correctly recognized by gpsbabel, the
script make only textual manipulation on his output...
It can be that gpsbabel download the column with a different tag from
the other garmin gps, and this tag is not included in csv stylesheet...
If the problem is only on one gps receiver model, I think it his hard to
fix (we had to download a meaningless column for all others gps
receivers), but if it is common problem, we had to fix it.
Leonardo, please try watching on temporary files to see if I'm right.
PS Please report if it happens on other receivers...
Davide
