[GRASS-dev] v.proj transforming z co-ordinates
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Dec 5 16:47:04 EST 2006
On Tue, 5 Dec 2006, Maciej Sieczka wrote:
> Paul Kelly wrote:
>> Hello Maciek
>> We're talking about your example at
>> http://grass.itc.it/pipermail/grass5/2006-September/025668.html, right?
> Right.
>> In that case both your co-ordinate systems are based on the same
>> ellipsoid (WGS84) so it is normal and expected for the ellipsoidal
>> height to stay the same.
> Sorry, but I'm quite a dummy as to ellipsoids vs height. So I should
> expect a difference whether using the '-z' switch only when
> reprojecting between 2 different ellipsoids, correct?
Yes. It is really not a very useful feature at all, quite confusing
actually, and that's why I thought it was important to make it optional.
Ellipsoidal height is not very useful because you can't use it to work out
e.g. if a ball is going to roll down a hill. In theory the ellipsoidal
height of the bottom of a hill could be higher than the top of the hill -
what is more important in a practical situation is the height above the
geoid, which is what most vertical datums use. And that is totally
separate from the 2-D re-projection that the [rv].proj modules do. We've
talked about better vertical datum support in GRASS but it is so
complicated and would just open up a whole can of worms that I don't want
to get into right now...
>> I'm not clear on what output you were expecting?
> Well, you wrote yourself "That is very strange. Can you post the output
> from v.proj please to see if there are any clues?". So I did, and
> waited for your response.
Yes well I didn't quite pick up on that then either (the ellipsoids being
the same). It is quite hard to get your head around it and understand it
and I only saw that was the problem when looking at it afresh!
Paul
