[GRASS-dev] gis.m notes
Michael Barton michael.barton at asu.edu
Wed Dec 6 17:31:26 EST 2006
On 12/6/06 2:01 PM, "Jachym Cepicky" <jachym.cepicky at centrum.cz> wrote:
Jachym,
Thanks for the feedback. Here are a couple of quick responses. Maybe more
with some thought.
> Hi,
> I had some courses with GRASS newbies and so I had opportunity to
> observe them and see, what kind of trouble they are having with gis.m
> and GRASS modules.
> First I have to say, that nobody seemed to have real problems using
> gis.m and get her/his map or perform some data analysis on it, so: great
> work Michael and others!
Thanks. I'm glad to see that it is helping people be productive in GRASS.
> The major problem was, that the users expected, that the icon in
> list of layers  for current map display is active, so one can click on it and
> NOT the
> text (e.g. raster1). Even
> when the people knew allready, that they have to click on the text and
> not on the icon, firstly they tryed to click on the icon, which did not
> work. Would it be possible to make the icon active too?
This is a good idea. I don't know how hard it is to implement, but I'll see
what I can do.
> Second thing, if they start new map-display, their list of layers
> disappeared and they did not know, that the list of layers is somehow
> coresponding with (current) mapwindow. Maybe, it would be cool to add kind of
> tabs for each running display, so you would switch between map displays
> not only by clicking on them, but also in gis.m window just like e.g.
> firefox does.
It would be nice to have some kind of visual indication that you've got a
clean slate for each new display but any existing ones are still around. I
tried to do as you suggest and was unsuccessful. I ran into underlying
programmatic issues (or lack of ability). There is a notebook widget in
bwidgets, but I couldn't get it to work correctly in this way automatically
with switching displays. On the pragmatic side, the GIS Manager window is
pretty small and might run out of room with more than a few displays open.
On the other hand, maybe no one would want to open more than a few displays
simultaneously.
> It would be cool, if the mapwindow would redraw after new map is added
> to list of layers (just like arcgis does it) or if there would be some
> kind of switch for doing this.
I suggested this on the list and the majority opinion was to do the redraw
manually so people wouldn't have to wait for each change or addition to
update the display.
> And last thing, maybe I found some bug in new georectifier: mapset seems
> to be changed to source mapset (xy) after some conditions and GRASS has to be
> restarted. We
> reproduced this bug on 3 computers, but I did not have time to mark the
> steps, which are leading to this. I'll post some details in the future.
> I'm just writing this for the case, anybody else noticed this "feature".
In order to work correctly, the georectifier has to switch back and forth
between the xy location and the 'working' location. It *should* do this
seamlessly. I've run into problems when there is some kind of crash while it
is operating in the xy location. I've tried to trap all the possibilities
for this I've found. However, if you can document a place this is
consistently a problem, I'll try to trap it too.
> But as I said, it was great to see new people, who are able "just to
> work" with GRASS using the new GUI manager. Thanks a lot for your work!
> Jachym
Thanks.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
