[GRASS-dev] GRASS 6.2.1RC1 published
Bob Covill bcovill at tekmap.ns.ca
Tue Dec 12 12:34:21 EST 2006
On Tue, 2006-12-12 at 17:56 +0100, Maciej Sieczka wrote:
> >> There is still a bug in NVIZ, that usually after adding a vector point
> >> layer, removing it, and adding a new one, artifacts are displayed,
> >> including:
> >> 1. different icons then the chosen one, for some points
> >> 2. some points are displayed with random colors, not the one specified
> >> 3. line artifact happen to pop up
> >> See the attached screendump (spearfish: elevation.10m + archsites) and
> >> latest remarks in the http://intevation.de/rt/webrt?serial_num=4492.
> > do both of these issues exist in 6.2 and 6.3, or have they been fixed in
> > 6.3 but not backported?
> Both issues exist in 6.2 and 6.3.
This appears to be a bug in ogsf (Gp3.c) where it uses the adapted sites
library to load the vector points. I have been testing a modified
version where I load the points with direct calls to the vector library
(not sites). This seems to clear up the reported problem.
Once I have finished testing I will commit to cvs. This will also get
rid of the ogsf dependance on the temporary sites library.
Bob
> Maciek
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
