[GRASS-dev] Re: [Qgis-developer] Re: GRASS Unit Tests for Win Build
"Sören Gebbert" soerengebbert at gmx.de
Tue Dec 12 16:53:16 EST 2006
i made it. :)
I have copied the gproj, site and vect lib to the grass lib directory
to run the test suite.
The result is available here:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html_win32_msys/
It is quite similiar to the qgis-grass-build result:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html_win32/
Best regards
Soeren
-------- Original-Nachricht --------
Datum: Mon, 11 Dec 2006 14:11:34 -0900
Von: Gary Sherman <sherman at mrcc.com>
An: "Sören Gebbert" <soerengebbert at gmx.de>
Betreff: Re: [Qgis-developer] Re:  GRASS Unit Tests for Win Build
> On Dec 11, 2006, at 1:54 PM, Sören Gebbert wrote:
> > i have tried to run the grass test suite within the msys environment.
> > But the tests failed for many modules, because the library
> > libgrass_gproj.6.3.cvs.dll was not found.
> The library is in the top-level directory where qgis is installed
> (this is true for the latest test build). Try adding your qgis
> install directory to the path and then testing.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Micro Resources: http://mrcc.com
>    *Geospatial Hosting
>    *Web Site Hosting
> "We work virtually everywhere"
"Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's Cup-Yacht!
