[GRASS-dev] Patch for QGIS ticket 448 (cannot start database driver)
Markus Neteler neteler at itc.it
Sun Dec 17 12:54:28 EST 2006
To GRASS 6.3-CVS.
As far as I understand, QGIS uses GRASS from CVS to prepare the
winGRASS extension. 6.2.1 is completely lagging behind concerning
Windows fixes.
I think that it is fine like that.
Markus
On Sun, Dec 17, 2006 at 06:50:40PM +0100, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> to which branch?
> it would be good to have in 6.2.1(.1?), so coming qgis will have it by
> default?
> pc
> Markus Neteler ha scritto:
> > On Sun, Dec 17, 2006 at 05:53:25PM +0100, Radim Blazek wrote:
> >> Here is the patch for https://svn.qgis.org/trac/ticket/448
> >> (grass/lib/db/dbmi_client/start.c).
> >> Unfortunately if QGIS is compiled without stdin/stdout and then run
> >> from batch, cmd.exe or MSYS shell, it will open command window for a
> >> while always when a new GRASS database driver is started.
> >> Radim
> > Patch applied.
> > Markus
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFFhYNw/NedwLUzIr4RAlN1AJwJL/5AutK6VRdpR+FkAku2X7t8qwCeM+ny
> rq9Os2h1ZScONhYwbVRyoIA=
> =a6p9
> -----END PGP SIGNATURE-----
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
