[GRASS-dev] Re: [Qgis-developer] 448
Markus Neteler neteler at itc.it
Mon Dec 18 05:56:25 EST 2006
In the GRASS stable release tons of Windows fixes are
missing and it's rather impossible to backport them
(only if you have much time).
I have now merged the patch into GRASS 6.2 stable release as
well.
BTW: Radim, you have CVS write access, feel free to fix
directly.
Markus
On Mon, Dec 18, 2006 at 10:51:02AM +0100, Radim Blazek wrote:
> I think that QGIS shloud use GRASS stable release, but I am not
> sure if there are some important fixes missing in the last stable 6.2.1.
> For now stick with HEAD (currently 6.3.-cvs) where the patch was applied
> (it should become future stable 6.4.0) I asked also to apply the patch
> in 6.2 branch (it will be in the next stable 6.2.2).
> Please close the ticket once you update GRASS from CVS in msys.tar.bz2.
> Still there is the problem with (sometimes, according how qgis was compiled
> and started) flashing console when GRASS db driver is started.
> Anybody knows how to suppress console on Windows for a program
> run by spawnl() which must be started with stdin/stdout?
> Radim
> On 12/18/06, Tim Sutton <tim at linfiniti.com> wrote:
> >Hi
> >Yes - unless you are happy to use grass cvs head for the qgis release
> >and the patch is already in grass? If you want to use latest stable
> >only, I will update the msys.tar.bz2 file to the tagged grass stable
> >release and then apply the patch in the generally downloadable msys
> >tarball....?
> >Regards
> >Tim
> >On 12/17/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> >> I have fixed https://svn.qgis.org/trac/ticket/448
> >> but the patch must be applied to GRASS. So I left it open
> >> until the GRASS which will be used to build official QGIS binaries
> >> for windows is patched.
> >> We should let people know that this patch must be applied.
> >> Where should I add a warning? In README_windows.txt?
> >> Radim
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.qgis.org
> >> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> >Tim Sutton
> >Visit http://qgis.org for a great Open Source GIS
> >Home Page: http://linfiniti.com
> >Skype: timlinux
> >MSN: tim_bdworld at msn.com
> >Yahoo: tim_bdworld at yahoo.com
> >Jabber: timlinux
> >Irc: timlinux on #qgis at freenode.net
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
