[GRASS-dev] RFC: Module Option Parser
Markus Neteler neteler at itc.it
Fri Dec 22 03:36:11 EST 2006
Glynn Clements wrote on 12/21/2006 06:50 PM:
> Brad Douglas wrote:
>>> If most of the options only apply to a specific "mode", that suggests
>>> that each mode should be implemented as a separate module. If they
>>> share common code, make it a library.
>> I disagree.  Currently there are about 150 raster and 65 vector modules.
>> The list is not shrinking and becoming a bit unwieldy.
> I don't see a problem with having a large number of modules.
>From a user's perspective this can become very confusing.
I tried to introduce the "keywords" concept to make the user easier
navigate through the available algorithms, but didn't get much
feedback on this.
ls -l $HOME/grass63/dist.x86_64-unknown-linux-gnu/bin | wc -l
321
plus scripts is already too much in my opinion.
Markus
