[GRASS5] 755 on /usr/local/grass-6.1.cvs/docs/html/*.png
Markus Neteler neteler at itc.it
Wed Feb 1 06:46:55 EST 2006
On Tue, Jan 31, 2006 at 01:23:18AM +0000, Glynn Clements wrote:
> More generally, GRASS' naming convention (dots in program names) makes
> programs like r.out.{png,ppm,tiff} show up as PNG/PPM/TIFF files in
> graphical file managers. I suppose it's too late to change that now,
> although it might be worth forcing the .exe suffix onto binaries when
> compiling on Windows.
The .exe suffix is already there:
cd grass61/include/Make
grep EXE *
Module.make:PROG=$(BIN)/$(PGM)$(EXE_SUFFIX)
Platform.make:EXE_SUFFIX          =
Platform.make.in:EXE_SUFFIX          = @EXE_SUFFIX@
On MS-Windows, it is set to .exe.
But the real solution is that someone implements a C version
of r.out.gdal and then to get rid of r.out.{png,ppm,tiff}.
Markus
