[GRASS5] [bug #3876] (grass) g.proj: proj4= fails, wkt= works partialy
Maciek Sieczka via RT grass-bugs at intevation.de
Mon Feb 6 10:52:42 EST 2006
Creating new location from an EPSG code fails. Maybe due to Paul's recent
changes? This problem could be populate to 6.02 candidate as well then.
I tried to create a location from EPSG code 2180. There was no error, location
was created. My path to /usr/local/share/proj/epsg is ok. However the location
is not projected:
g.proj -p
XY location (unprojected)
Maciek
-------------------------------------------- Managed by Request Tracker
