[GRASS5] Re: [bug #4064] (grass) r.in.srtm: doesn't work, though it's a latlong WGS84 projection
Tue Feb 7 16:52:48 EST 2006
On 2/7/06, Markus Neteler <neteler at itc.it> wrote:
> Maciek,
> (cc Frank)
> I had the same problem with v.in.ogr today (using GDAL/OGR from CVS).
> Frank, did anything in GDAL/OGR recently change which makes fail the
> recognition of the GRASS location projection in r.in.gdal/v.in.ogr?
> This used to work.
Markus,
I can't think of anything.
Best regards,
