[GRASS5] [bug #4071] (grass) d.what.rast strange values outside of map area
Markus Neteler neteler at itc.it
Thu Feb 9 08:59:31 EST 2006
On Thu, Feb 09, 2006 at 02:09:41AM +0000, Glynn Clements wrote:
> Request Tracker wrote:
> > I discovered an unhelpful behaviour of the GRASS monitor
> > or d.what.rast resp.
> It's d.what.rast.
> > This bug persists despite the recent
> > display driver modifications (which may be unrelated to this).
> They are unrelated.
> > Test case:
> > #click into no data pixels at border (outside of map box):
> > d.what.rast
> d.what.rast makes no attempt to check that the selected cell is
> actually inside the map.
> If you click above or below the map, you should get warnings from
> libgis that the program attempted to read an invalid row, e.g.:
> 	WARNING: [elevation.dem in PERMANENT] - read request for row 148 is outside
> 	         region
> 	elevation.dem in PERMANENT  (Null)ERROR reading cell file
> G_get_c_raster_row() will fill the buffer with zeros (not nulls) if
> you ask for an invalid row. Arguably it should use nulls, although
> this case shouldn't be allowed to happen anyhow.
> If you click to either side of the map, d.what.rast will end up
> reading from outside the buffer.
> > Is this related to
> >  http://www.intevation.de/rt/webrt?serial_num=2986&display=History
> No.
> > A fix would be appreciated. I don't know where to look for that.
> display/d.what.rast/what.c
> It needs a check along the lines of:
> 	if (row < 0 || row >= nrows || col < 0 || col >= ncols)
> 		/* outside map */
Thanks, I have added a test now. If you click outside of
the map, this message appears:
You are clicking outside the map
Example:
Buttons
 Left:  what's here
 Right: quit
962.7016129(E) 599.7983871(N)
hemisphere in neteler, quant   (161)
hemisphere in neteler, actual  (160.717143)
1192.54032258(E) 636.08870968(N)
1281.25(E) 672.37903226(N)
Problem solved. Strangely: it must have been since the
existance of d.what.rast or at least after NULL introduction ?!?
Markus
