[GRASS5] [bug #4077] (grass) r.region: region option missdescribed
Sat Feb 11 18:36:21 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4077
> Subject: r.region: region option missdescribed
> Platform: GNU/Linux/x86
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs 2006.02.11
> is
> region   Set current region from named region
> should be
> region   Set map's region to match this saved region file
I've removed the word "current", i.e.
	region   Set region from named region
That's consistent with all of the other options.
