[GRASS5] mingW: how to exclude win32_pipes.c & user_config.c from compilation?
Radim Blazek radim.blazek at gmail.com
Mon Feb 13 04:36:34 EST 2006
On 2/11/06, Markus Neteler <neteler at itc.it> wrote:
> On Sat, Feb 11, 2006 at 01:28:47AM +0000, Glynn Clements wrote:
> > Markus Neteler wrote:
> > > we have to exclude compilation of
> > > lib/gis/win32_pipes.c
> > > lib/gis/user_config.c
> > > when compiling with mingW.
> > Huh? The whole of win32_pipes.c is conditionalised upon
> > "#ifdef __MINGW32__", so if that file isn't wanted for MinGW, it
> > should just be removed.
> > > How to modify the Makefile?
> > > Is there a way to define an EXCLUDE variable in this
> > > Makefile and make include/Make/Lib.make aware of it?
> > > I know too little about Makefile programming to implement
> > > it correctly. Throwing files away may not be the solution.
> > The usual approach is to just conditionalise the entire source file
> > upon a macro, so that you effectively get an empty file if the test is
> > false.
> I don't know - this was a request by Radim, I suggested
> to him to remove the files. Let's listen to him.
Those two files do not compile with MinGW but they are not
used in fact. The files were not in the list of files for compilation
in Makefile but with the recent change which is using *.c
appeared in the list. I only want that it compiles. Do whatever
you prefer. I just worry that if we delete the files the code will be
forgoten for ever.
Radim
