[GRASS5] New release candidate 3 of GIS Manager 2
Michael Barton michael.barton at asu.edu
Wed Feb 15 18:59:15 EST 2006
Maciek,
I see what you are talking about. But the GIS Manager is NOT doing this. The
zooming in the new GIS Manager does NOT use d.zoom. It simply resets the
region extents--extents ONLY--by issuing a g.region n=y1 s=y2 e=x1 w=x2 (no
change to resolution)
I tried adding the -a flag and it makes no difference. It looks like it is
some kind of a rounding issue in g.region (or possibly in the OS). In a
working context the change is a tiny fraction of a mm in your example below.
So it wouldn't make any meaningful difference in most cases. However, it is
odd that it happens. Maybe someone who understands the g.region code can
explain it.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: Tue, 14 Feb 2006 21:12:17 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass5 at grass.itc.it>, <GRASSLIST at baylor.edu>
> Subject: Re: [GRASS5] New release candidate 3 of GIS Manager 2
>> Zoom does NOT change resolution, only EXTENTS.
> But it really DOES change the region. Try for yourself:
> 1.
> $ g.region rast=u65_10k_rogow -ap
> projection: 1 (UTM)
> zone:       33
> datum:      wgs84
> ellipsoid:  wgs84
> north:      5681438
> south:      5676368
> west:       596952
> east:       603815
> nsres:      1
> ewres:      1
> rows:       5070
> cols:       6863
> 2.
> Display in gis.m, zoom in once.
> 3.
> $ g.region -p
> projection: 1 (UTM)
> zone:       33
> datum:      wgs84
> ellipsoid:  wgs84
> north:      5679541.73929
> south:      5678636.76827
> west:       600274.248772
> east:       601286.741103
> nsres:      0.99996798
> ewres:      0.99949885
> rows:       905
> cols:       1013
> As you can see the resolution changed. Please don't do it.
>> controlled by g.region. Nothing I can do about that.
> Use "g.region -a" instead?
> Who can say what d.zoom is doing that it is not changing the res at
> zooming in/out?
