[GRASS5] current position
Fri Feb 17 03:07:25 EST 2006
Huidae Cho wrote:
> > OTOH, it's not fine for a client to rely upon any specific behaviour
> > regarding what those functions do to the current point.
> I got your point.  Then the following sequence should isolate the box from line
> (10, 10) -- (20, 20).
> R_move_abs(10, 10);
> R_cont_abs(10, 10);
> R_box_abs(WHATEVER);
> R_cont_abs(20, 20);
The final R_cont_abs() doesn't make sense. There should always be an
R_move_abs() between any box or polygon function and any R_cont_*() or
R_*_rel() function.
> Then, we have to correct comments above R_(box|polygon)_*
definitions.
Yes.
> If I'm right, would you please?
Done.
