[GRASS5] Re: [GRASSLIST:10403] Transparency added
Martin Landa landa.martin at gmail.com
Sun Feb 19 06:56:35 EST 2006
It is great!
Thanks a lot!
Martin
2006/2/19, Huidae Cho <grass4u at gmail.com>:
> I've added transparency feature to display drivers (XDRIVER and PNG) and d.rast
> and d.vect now have transparency= (%) option.  You can find a screenshot
> attached in which two rasters and one vector are overlaid.
> # opaque drawing
> d.rast dem
> # 80% transparency, -o is needed not to clip previous drawings
> d.rast landuse trans=80 -o
> # 90% transparency with blue area fill
> d.vect subbasins trans=90 fcolor=blue
> Please find attached the png file.
> I hope you enjoy this.
> Huidae Cho
