[GRASS5] dm and gism in the cvs
Michael Barton michael.barton at asu.edu
Sun Feb 19 22:07:00 EST 2006
Bernhard,
Again. Thanks.
A couple of clarifications. I did a cvs add and commit. I didn't move files.
I did copy them from my local /display directory to my local new /gui/tcltk/
directory before adding them but after adding the new directory to the cvs
(obviously I wouldn't rewrite them). But clearly it didn't work correctly.
I've done this before--recently--with no problems. But I've never done this
many files at one time. It doesn't make much sense to me, but maybe this was
the source of the source of the problem? It would be nice to know WHY the
add/commit didn't work this time so I could avoid a similar problem in the
future.
The files in the tarball I sent you should be the same as those that existed
in the original location. In fact, I simply copied my local versions of the
original directories into a backup directory (i.e., the one that I sent you)
prior to starting the process to add/commit, move/commit. The apparent
mismatch between the new and old locations is moot now in that the new
location is the place everyone should be working with.
Copy tree.tcl was a working file that was not supposed to end up in the cvs.
I deleted it when I did the add/commit to the new location (i.e., it was in
my backup but not the new location). But of course that didn't work right.
So I'm glad you did not add it either.
Thanks again for the emergency help.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Bernhard Reiter <bernhard at intevation.de>
> Date: Sun, 19 Feb 2006 19:57:54 +0100
> To: <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] dm and gism in the cvs
> On Fri, Feb 17, 2006 at 02:17:35PM -0700, Michael Barton wrote:
>>    I had some problems adding dm and gism to their new locations in
>>    /gui/tcltk and didn't realize it until a few minutes ago. I think
>>    (hope) I've remedied this and they are in the cvs now.
> Michael, All,
> I have fixed this yesterday (and my nice explanation emails somehow
> did not make it to this list, so here is a brief version).
> To me it looked like Michael's CVS client did not work properly.
> I have not moved the files, please make sure that you all check out/update
> display/ and gui/ properly before new commits.
> As Michael has send my a tarball, I have added a bunch of new files
> to gui/tcltk/gis.m/ that have not been in the old location.
> One file I did NOT add was "copy tree.tcl" or so.
> Michael: I suggest that you rename this file to not contain
> a space character before adding.
> CVS general insights:
> The move could be done with regular cvs add and cvs remove commands.
> This was better then moving files within the repository, because now
> people can still check out old non-branch-tags and get the same files.
> Other:
> When looking at new files, I have noticed that they do not contain
> a hint towards the license and the right holder.
> I suggest to add this as a standard header in addition to the author(s).
> My memory tells me that we debated standard headers quite a while before
> on this list.
> Best,
> Bernhard
