[GRASS5] version.h.in broken
Tue Feb 21 18:17:41 EST 2006
This change:
  RCS file: /grassrepository/grass6/include/version.h.in,v
  Working file: include/version.h.in
  head: 1.3
  branch:
  locks: strict
  access list:
  symbolic names:
  	grass_6_0_0: 1.2
  	releasebranch_6_0: 1.2.0.2
  	grass_6_0_0_beta_2: 1.2
  	grass_6_0_0_beta_1: 1.2
  	release_17_06_2004_grass5_7_0: 1.1
  keyword substitution: kv
  total revisions: 3;	selected revisions: 1
  description:
  revision 1.3
  date: 2006/02/21 09:02:07;  author: radim;  state: Exp;  lines: +4 -0
  added defines
breaks version.h by changing GRASS_VERSION_{MAJOR,MINOR,RELEASE} from
strings to integers.
In particular, this causes the display drivers to segfault when trying
to create the socket:
unix_socks.c: In function `_get_make_sock_path':
unix_socks.c:79: warning: passing arg 1 of `strlen' makes pointer from integer without a cast
unix_socks.c: At top level:
Although less critical than the drivers, G_version() will also segfault:
version.c: In function `G_version':
version.c:19: warning: passing arg 1 of `strlen' makes pointer from integer without a cast
version.c:21: warning: format argument is not a pointer (arg 3)
version.c:23: warning: passing arg 1 of `strlen' makes pointer from integer without a cast
version.c:25: warning: format argument is not a pointer (arg 3)
