[GRASS5] recent cvs d.m gis.m errors
Wed Feb 22 06:31:19 EST 2006
Andrew Danner wrote:
> I did a cvs update Tuesday 21 Feb around 23Z and d.mon x0, d.m and gis.m
> all give runtime errors (see below).  Is this a temporary problem or am
> I doing something wrong?  I'm using Ubuntu (Hoary) on x86. I usually use
> tcl/tk 8.3 but when that wasn't working I also tried 8.4 with the same
> result. nviz pops up the UI box, but no visualization window.
> Ideas?
> -Andy
> CXXFLAGS='-g -O2 -D_LARGE_FILE_SOURCE -D_FILE_OFFSET_BITS=64' CFLAGS='-g
> -O2 -D_LARGE_FILE_SOURCE -D_FILE_OFFSET_BITS=64' ./configure
> --with-tcltk-includes=/usr/include/tcl8.4/ --without-postgres --with-cxx
> --enable-largefile
> GRASS 6.1.cvs (Neuse):~ > d.mon x0
> Problem selecting x0. Will try once more
> Error in startup script: child process exited abnormally
A recent change to version.h.in causes the drivers to segfault at
startup.
If dist.<arch>/include/grass/version.h has three #define directives at
the bottom, you need to remove them then re-compile lib/gis.
