[GRASS5] pointer.gif missing?
Andrew Danner adanner at cs.duke.edu
Wed Feb 22 13:03:49 EST 2006
Kirk,
I had the same problem. Glynn just fixed the d.mon error in CVS. As for
the gis.m error, the pointer.gif file is missing. Does anyone else know
where to get this file? As a temp fix, I copied some other icon
"erase.gif" in the etc/gm dir to
usr/local/grass-6.1.cvs/etc/gm/pointer.gif and it seems to work.
-Andy
On Wed, 2006-02-22 at 10:25 -0600, Kirk R. Wythers wrote:
> I just cvs updated (20060222)and can no longer start d.m or d.mon.
> d.m fails with:
> GRASS 6.1.cvs (minnesota_utm):~ > gis.m
> Error in startup script: couldn't open "/usr/local/grass-6.1.cvs/etc/
> gm/pointer.gif": no such file or directory
>      while executing
> "image create photo -file "$gmpath/pointer.gif""
>      (procedure "MapToolBar::create" line 33)
>      invoked from within
> "MapToolBar::create $map_tb"
>      (procedure "MapCanvas::create" line 47)
>      invoked from within
> "MapCanvas::create"
>      (procedure "Gm::startmon" line 11)
>      invoked from within
> "Gm::startmon"
>      (procedure "Gm::create" line 96)
>      invoked from within
> "Gm::create"
>      (procedure "main" line 29)
>      invoked from within
> "main $argc $argv"
>      (file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 777)
> and d.mon x0 fails with:
> GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
> Problem selecting x0. Will try once more
> Any thoughts?
> Kirk
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
