[GRASS5] d.m and d.mon fail after cvs update
Michael Barton michael.barton at asu.edu
Thu Feb 23 16:27:29 EST 2006
Glynn,
Currently when I use monitor override, I cannot open an xmon window from the
GIS Manager. I get a 'No socket to connect to for monitor <x0>' error.
The way I had it was ...
d.mon start=gism -s
set env(MONITOR_OVERRIDE) "gism"
...display commands
d.mon stop=gism
If I try to start an xmon (e.g., for v.digit), I get the 'No socket...'
error.
If I change to...
d.mon start=gism
...display commands
d.mon stop=gism
I get no error.
I've tried using monitor override to select the xmon for v.digit (or other
module that needs it) and unsetting monitor override after stopping gism.
This is not a big issue now. But when I start redoing the compositing, I'll
want to keep gism running all the time, except when doing a window resize.
Then I'll really need to use monitor override.
Any ideas?
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Thu, 23 Feb 2006 14:59:19 +0000
> To: Michael Barton <michael.barton at asu.edu>
> Cc: "Kirk R. Wythers" <kwythers at umn.edu>, devel grass <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] d.m and d.mon fail after cvs update
> Michael Barton wrote:
>> I had this problem, but fixed it in a different way and so need to ask about
>> it.
>> I had a strange monitorcap (with double xmon definitions) file that came
>> with the most recent (13 February) Mac binary from Lorenzo Moretti. Perhaps
>> this is/was being generated during Mac compiles as this seems to be reported
>> by Mac folks.
>> When I fixed the monitorcap file AND commented out the following line...
>>                 #set env(MONITOR_OVERRIDE) "gism"
>> in the procedure that creates the output PPM and then creates a TclTk image
>> from thePPM, it worked.
>> With the fix you mention below, should I try uncommenting the
>> MONITOR_OVERRIDE statement?
> The use of MONITOR_OVERRIDE and the fix which I mentioned are
> unrelated.
> Without the version.h.in fix, monitor drivers will simply segfault at
> startup. the fix is necessary to be able to use monitors.
> MONITOR_OVERRIDE allows applications to redirect d.* commands to a
> specific monitor without using "d.mon select=..." (which will
> interfere with the user's use of monitors).
> gis.m should always be using MONITOR_OVERRIDE rather than
> "d.mon select=gism".
> BTW, It is now be possible for gis.m (and similar programs, e.g.
> d.out.png) to avoid the use of monitorcap altogether. You can start
> monitors directly with e.g. (shell syntax):
> $GISBASE/driver/PNG foo '' ''
> MONITOR_OVERRIDE=foo d.vect fields
> d.mon stop=foo
> # or:
> # $GISBASE/etc/mon.stop foo
> without the monitor name having to appear in the monitorcap file.
> This doesn't work when using FIFOs, although I don't know if anyone
> still uses FIFOs, and I'm inclined to remove FIFO support altogether
> unless someone can provide a good reason why it needs to stay.
