[GRASS5] Makefile problem - Re: [GRASS-announce] GRASS 6.0.2RC3 released
Tue Jan 3 12:13:44 EST 2006
> >     * bugfix for 'builddemolocation target' in Makefile
> >       when building as root (RPMs etc)
> Unfortunately I still have the following problem:
> [root at bild-mandriva2006 dist.i686-pc-linux-gnu]# ls -l dist.i686-pc-linux-gnu/
> insgesamt 40
> drwxr-sr-x   3 1338  204 4096 Jan  3 14:21 demolocation/
> drwxr-xr-x   3 root root 4096 Jan  3 14:22 docs/
> drwxr-xr-x   4 root root 4096 Jan  3 14:22 bwidget/
> drwxr-xr-x   2 root root 4096 Jan  3 14:22 fonts/
> Although 'tar' is used in the 'builddemolocation' target in the
> main Makefile, the owner is still preserved (1338 above).
> It must be the owner compiling GRASS (here, root), otherwise the
> virtual session to generate the HTML manuals fails.
> Any ideas?
       -o, --no-same-owner
              do not attempt to restore ownership when extracting; -o exhibits
              this behavior when extracting an archive
