[GRASS5] Automated test-system for basic functionalities.
Markus Neteler neteler at itc.it
Mon Jan 9 07:29:44 EST 2006
Hi Stephan,
Soeren Gebbert and me have recently started to work on a test
suite. I suggest to get you involved, probably offlist for
now and to send to you the current scripts for testing.
Anyone else interested may write to us.
The current test suite isin fact Spearfish based since this
is a well know data set.
Once the test suite is tested a bit more, we can move
it to CVS.
Sounds good?
Markus
On Mon, Jan 09, 2006 at 12:36:30PM +0100, Stephan Holl wrote:
> Hi Developers,
> we discussed a automated test-system for modules which
> will report simple OK/error statements for basic functionalities.
> Currently there is no clear idea, but thoughts about a shell-script
> with configuration file have been made.
> The dataset is also a problem, since it must be small enough to
> distribute it to testers. Spearfish is probably too big...
> A manual example (with spearfish6-data) can be found here[1].
> Perhaps someone on this list can give some ideas, thoughts about
> best-practice of creating such a test-environment?
> Thank you for input!
> Stephan
> [1] http://mpa.itc.it/markus/mum3/testing_grass6_software.txt
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
