[GRASS-dev] [bug #4794] (grass) r.thin
Maciek Sieczka via RT grass-bugs at intevation.de
Wed Jul 5 14:17:29 EDT 2006
Hi
> Hi, I'm using r.thin command, and it seems that it changes Nodata value
> cells of the original raster (surrounding cells obtained after the
> gereference operation of à scanned map) to the value 1
Could you put screenshots that explain your problem (and the input and
problematic output data if possible) somewhere? What was your r.thin syntax
exactly?
What Grass version? Platform?
> Does soemone already had this problem,
I haven't, I think.
> is it possible to change nodata value to 0 for example
r.null?
Maciek
-------------------------------------------- Managed by Request Tracker
