[GRASS-dev] Re: r.topmodel: doubled 'ovewrite switch'
Huidae Cho grass4u at gmail.com
Tue Jul 18 15:40:17 EDT 2006
Fixed in CVS.
Cheers,
Huidae Cho
On Tue, Jul 18, 2006 at 08:16:52PM +0200, Maciej Sieczka wrote:
> Hi!
> r.topmodel has it's own 'overwrite output' switch. Since the Grass-wide
> '--ovewrite' has been documented, r.topmodel manual reads:
> -o
>     Overwrite outputs
> --overwrite
>     Force overwrite of output files
> Does the r.topmodel's '-o' imply exactly the same as the Grass-wide
> '--ovewrite'? Could the r.topmodel's own switch be removed now?
> Maciek
