[GRASS-dev] gis.m fails to start
Markus Neteler neteler at itc.it
Thu Jul 27 14:50:02 EDT 2006
Morten,
I guess that g.region is linked against gdal which
is probably compiled *with* mysql support on your
system?
ldd `which g.region`
Markus
On Thu, Jul 27, 2006 at 06:56:54PM +0200, Morten Hulden wrote:
> Hi,
> is this a bug that only shows up on my distro (Fedora 5). Why would
> mysql client libs be needed even when I compile without mysql support?
> cvs version 20060727
> GRASS 6.1.cvs (map18):~ > gis.m &
> GRASS 6.1.cvs (map18):~ > Error in startup script: g.region: error while
> loading shared libraries: libmysqlclient.so.14: cannot open shared
> object file:  No such file or directory
>     while executing
> "close $input"
>     (procedure "MapCanvas::zoom_gregion" line 13)
>     invoked from within
> "MapCanvas::zoom_gregion $mon"
>     (procedure "MapCanvas::create" line 46)
>     invoked from within
> "MapCanvas::create"
>     (procedure "Gm::startmon" line 11)
>     invoked from within
> "Gm::startmon"
>     (procedure "Gm::create" line 74)
>     invoked from within
> "Gm::create"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 528)
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
