[GRASS-dev] Mac OS X frameworks for support libraries
Michael Barton michael.barton at asu.edu
Sat Jul 29 20:01:12 EDT 2006
Agustin,
It¹s not as bad as it seems for you. I¹ll explain.
1. I think your problem about the location means that your gis database is
incorrectly set. You can either fix this by editing .grassrc6 or starting
GRASS in text mode and setting it there. The fact that you only have a
problem with the main user is a clue.
2. I think (and I¹m copying William here to clarify) that NVIZ works OK on
Intel MacBooks if you run it in x11 mode. It does not work in TclTk aqua
mode. But maybe this is incorrect.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Sat, 29 Jul 2006 22:39:59 +0200
To: William Kyngesburye <kyngchaos at kyngchaos.com>
Cc: <grass-dev at grass.itc.it>, Michael Barton <michael.barton at asu.edu>
Subject: Re: [GRASS-dev] Mac OS X frameworks for support libraries
William's comments explain me what is going on a IBook, grass doesn't work
and the terminal keeps giving a message about location not being initialized
(I don't remember the exact message now). This weird behavior happens only
in the main user. It seems that somehow
Sad to hear that NVIZ doesn't work at all in MacIntel I want to buy a
MacBookPro.
In some of my several attempts to compile grass, NVIZ was working when
started from X11 terminal, but after get rid of the problems the errors
messages when compiling nviz doesn't work.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060729/d99a4f16/attachment.html
