[GRASS-dev] cvs gis.m error
Trevor Wiens twiens at interbaun.com
Tue Jun 6 02:22:32 EDT 2006
On Mon, 05 Jun 2006 21:26:46 -0700
Michael Barton <michael.barton at asu.edu> wrote:
> I'm running Lorenzo's binaries of 27 May with no problems in general. Check
> in gronconsole to see if there are any errors reported there.
It simply shows that the command d.mon start=gism -s
is still running. That's it. Stopping the existing display and opening
an new one doesn't resolve the problem. No errors, but also no display
either.
When I modify the run command in runandoutput.tcl to stop sending
everything to /dev/ null, the following happens. The error appears
sooner with the message No such monitor gism on the command
d.mon stop=gism
with the rest being pretty much as before.
Hmm....
BTW, this makes me wonder about the wisdom of sending everything
to /dev/null. A session log file makes more sense to me.
When I revert to an earlier version of the code (one which I was
playing with so I revert to different versions of mapcanvas.tcl and
maptool.tcl the errors are identical so it would seem to have something
to do with d.mon on my system. Has that changed recently?
T
> > child process exited abnormally
> >     while executing
> > "exec -- d.mon start=gism -s >& /dev/null"
> >     ("eval" body line 1)
> >     invoked from within
> > "eval exec -- $cmd $args >& /dev/null"
> >     (procedure "run" line 6)
> >     invoked from within
> > "run d.mon start=gism -s"
> >     invoked from within
> > "eval run $cmd $args"
> >     (procedure "runcmd" line 6)
> >     invoked from within
> > "runcmd "d.mon start=gism -s""
> >     (procedure "MapCanvas::driversettings" line 55)
> >     invoked from within
> > "MapCanvas::driversettings $mon"
> >     (procedure "MapCanvas::drawmap" line 39)
> >     invoked from within
> > "MapCanvas::drawmap $mon"
> >     (procedure "MapCanvas::display_server" line 9)
> >     invoked from within
> >     ("after" script)
> > After this I can add layers to the tree view but nothing displays.
> > Any suggestions?
> > T
> > Trevor Wiens
> > The significant problems that we face cannot be solved at the same
> > level of thinking we were at when we created them.
> > (Albert Einstein)
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Trevor Wiens
(Albert Einstein)
