[GRASS-dev] Re: v.in.dxf: support for 3DFACE?
Michael Barton michael.barton at asu.edu
Tue Jun 6 11:48:56 EDT 2006
I haven't kept up with v.in.dxf since initially testing it and cheering its
incorporation into GRASS 6. But I'll be needing it soon and some of my
colleagues are using it quite a bit.
Is there a way to maintain a dxf entity attribute as a cat/attribute for
areas? The object it to avoid going through the complication of converting
lines to boundaries, adding centroids, adding cats, and linking cats with
attributes.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Huidae Cho <grass4u at gmail.com>
> Date: Tue, 6 Jun 2006 10:16:03 -0500
> To: Hamish <hamish_nospam at yahoo.com>
> Cc: grass5 <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Re: v.in.dxf: support for 3DFACE?
> Hamish,
> On Wed, Jun 07, 2006 at 02:23:22AM +1200, Hamish wrote:
>> Hi,
>> all excited to try out v.in.dxf :) but 3DFACE isn't implemented yet :(
>> I can convert the DXF to a polyline version, and import with the new -f
>> flag, but I need to run v.build before I can display it. After that I
> I fixed this bug.
>> can do g.region v=, display with d.vect, & display in NVIZ (3D vector).
>> Looking in v.info the x,y,z ranges are all 0,0.
>> Note the final x,y ranges are both negative. (?)
>> after import:
>>  |            N: 0.000         S: 0.000                      |
>>  |            E: 0.000         W: 0.000                      |
>>  |            B: 0.000         T: 0.000                      |
>> after v.build:
>>  |            N: -4816.565     S: -5951.313                  |
>>  |            E: -1943.884     W: -3092.723                  |
>>  |            B: -11.644        T: 54.011                    |
> Well, I think usual coordinates in DXF are not geographic coordinates, but it
> depends on DXF files.
>> Also it exits with "No DXF layers found!" for the 3DFACE import.
>> This had me really puzzled as the layer does exist, it is just all
>> of unknown feature types. Could the error message be improved?
>> "... with data!"
>> "Layers found with no features"
>> "No features in layer"
> v.in.dxf does not count layers it cannot import.
>> Any plans for 3DFACE support? The wireframe is good stuff, but just a
>> skeleton. :)
>>  http://www.autodesk.com/techpubs/autocad/acad2000/dxf/3dface_dxf_06.htm
>> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.dwg/entity.c?rev=HE
>> AD&content-type=text/vnd.viewcvs-markup
> Could you send me a sample DXF for 3DFACE and its screenshot?
> Thank you.
> Huidae Cho
