[GRASS-dev] Re: [STATSGRASS] propagating temporary files
Markus Neteler neteler at itc.it
Wed Jun 7 06:01:15 EDT 2006
On Wed, Jun 07, 2006 at 07:59:29PM +1200, Hamish wrote:
> On Wed, Jun 07, 2006 at 03:23:47PM +0800, rsadler at cyllene.uwa.edu.au wrote:
> > I can disappear these files at run-time, but the strange thing is that
> > this didn't appear to be a problem a couple of a weeks ago.
Some months ago we introduced scripts (also commands?) which created
subdirectories within $MAPSET/.tmp/ but the $GISBASE/etc/clean_temp
wasn't yet changed accordingly.
> usually $GISBASE/etc/clean_temp is run at GRASS startup and exit to
> flush the $MAPSET/.tmp/ dir. At your own risk you can call it within
> your GRASS session to clean out the muck.
The current clean_temp program fails to remove subdirectories in
/.tmp/ which are sometimes created.
I have received a new version of clean_temp (written by Roberto Flor)
which needs to be tested:
http://mpa.itc.it/markus/tmp/clean_temp2.c
This new version removes also subdirectories generated in the
$MAPSET/.tmp/ dir.
Markus
