[GRASS-dev] Re: grass-dev Digest, Vol 2, Issue 19
Sun Jun 11 03:01:23 EDT 2006
Brad Douglas wrote:
> Export to image formats are still broken (some segv(), some write bad
> data).  Animation via ffmpeg 'works', but again, writes bad data.
> The 64bit data corruption and segv() issues needs to be fixed before 6.2
> goes gold.  I'll see if I can't hunt down and correct the segv()s this
> weekend.
I'm looking into the OGSF image handling stuff right now.
