[GRASS-dev] grass6.2?
Mon Jun 12 01:24:52 EDT 2006
Michael Barton wrote:
> I noted the difference because i.rectify reads from the current location and
> writes to the location specified by i.target.
Ah. That is something which its replacement shouldn't imitate.
Reading from a different location or mapset is reasonable enough, but
nothing should write outside of the current mapset. The case of
r.in.gdal creating a new location is probably OK, but writing to an
existing mapset (other than the current one) isn't.
BTW, does i.rectify bother to lock the destination mapset?
