[GRASS-dev] grass6.2?
Michael Barton michael.barton at asu.edu
Mon Jun 12 14:06:17 EDT 2006
Markus,
I've been trying to complete a non-x11
i.points/i.vpoints/v.transform/i.rectify replacement in TclTk.
What you are talking about sounds nice, but I can't do the work in C. Also,
we need something that does not depend on interactive x11 displays. I
haven't worked with the linear features modules yet, and so have not tried
to fold them into the georectifier in this version. I should probably get it
running completely before trying to expand it.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Markus Neteler <neteler at itc.it>
> Date: Mon, 12 Jun 2006 18:40:13 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] grass6.2?
> Michael,
> no, the new functions aren't yet in CVS:
> I wrote:
> Not related to GUI, but related to a new i.points (as long time promised):
> http://mpa.itc.it/markus/tmp/i.points.auto_30_mar_2006.tar.gz
> This should be the merge of i.points + i.vpoints along with
> homography support (geocoding by lines instead of points which is
> much easier/faster) and auto-GPC search (based on Fourier correlation).
> There is a file HANDBOOK inside which explains it a bit. Today
> I found some raster-map negative row bug, maybe someone wants to give it
> a try? Would be fun to have that in GRASS soon.
> So a couple of files (a few) need to the added/modified in i.points to
> get that functionality.
> Markus
> Michael Barton wrote on 06/12/2006 06:37 PM:
>> Markus,
>> Are these in the cvs as part of the normal compilation? If so, they should
>> go into the menu.
>> I've been tied up in other stuff and so haven't updated the menu much
>> lately. Also, I was unsure how to do it after Cedric's changes (still unsure
>> about a few issues).
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Mon, 12 Jun 2006 09:34:23 +0200
>>> To: <grass-dev at grass.itc.it>
>>> Michael,
>>> just curious: do you intend to also include the
>>> new developments:
>>> - homology based rectification with lines
>>> - Fourier correlation based auto search of GCPs
>>> See:
>>> http://grass.itc.it/pipermail/grass-dev/2006-March/022051.html
>>> for link to the source code.
>>> Markus
>>> On Sun, Jun 11, 2006 at 11:51:13PM -0700, Michael Barton wrote:
>>>> Is there a reason to change i.rectify at some point so that it also will
>>>> read from a different directory and write to the current one? This is how
>>>> the georectifier works, but I have to switch back and forth between
>>>> locations/mapsets to make i.rectify work.
>>>> I have no idea about the locking. But probably not or I would have probably
>>>> run into it like I did with g.mapset.
>>>> Michael
>>>> Center for Social Dynamics & Complexity
>>>> phone: 480-965-6213
>>>> fax: 480-965-7671
