[GRASS-dev] NVIZ panel menu
Markus Neteler neteler at itc.it
Wed Jun 14 17:01:13 EDT 2006
On Wed, Jun 14, 2006 at 09:59:30PM +1200, Hamish wrote:
> Hi,
> still on the 3D faces theme,
> in the NVIZ panel menu we have:
> Surface
> Vector Lines
> Vector Points
> Volumes
> The "Vector Lines" panel actually controls 3D faces as well.
> I was going to change it to be "Vector Lines and Surfaces", but
> then the menu reads:
> Surface
what about
 Vector Lines and 3D Polygons
> Vector Points
> Volumes
> ... too many "Surfaces". I'm at a loss as to what name it.
Surfaces is sort of reserved for raster maps in NVIZ.
> e.g.
> Raster Surfaces
> Raster Volumes
> Vector Points
> anyone have a bright idea?
mine above? :-)
> AFAIK vector areas are still unsupported in NVIZ?
You mean that "soils" in Spearfish is rendered as boundaris
only?
> Will "v.type type=boundary,face" work around that?
I don't think so because faces are usually 3D (so v.drape?).
But I am not sure.
 Markus
