[GRASS-dev] Re: [bug #4450] (grass) g.remove vect: empty dirs in the $MAPSET/.tmp/$HOSTNAME left
Mon Jun 19 01:52:08 EDT 2006
Hamish wrote:
> > remove() is ANSI, whereas unlink() and rmdir() are POSIX.
> What's our target anyway - ANSI C or POSIX compliance?
ANSI where possible (and practical), POSIX where necessary.
Note that ANSI C's I/O functionality is inadequate for non-trivial
programs, e.g. it doesn't say anything about directories (a system
doesn't even have to /have/ directories to fully implemement ANSI C).
