[GRASS-dev] Re: [GRASS-user] CVA installation
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Jun 22 04:28:47 EDT 2006
Gary,
all you need to know is where your GRASS has been installed
when you (or whoever did the installation) did the
make install
for the CVS sources.
If the defaults weren't changed, chances are pretty high that
everything went into
/usr/local/grass-6.1.cvs
and that would be the location you have to specify with
the --grass= option.
An alternative is to first start GRASS, then use GEM
from within the GRASS shell. In that case, GEM will
figure out the install path by itself and you don't
need to give the --grass= option.
Benjamin
gary wrote:
> Sounds good. It's a bit late to start hacking (about 1AM on the west
> coast of the US), but I will give it a shot tomorrow (technically
> today). Moving the cva to gem is a snap. Finding those locations is
> tricky since it assumes you know how grass is built.
> Thanks in advance for the advice.
> Benjamin Ducke wrote:
>> Gary,
>> several things:
>> 1. The version of r.cva on my homepage was hopelessly outdated. You
>> would not get that to compile on a recent version of GRASS CVS.
>> Sorry about this. I just updated the file on my homepage. It will
>> from now on *only* work with GRASS 6.1 CVS. Please download that
>> version and try again.
>> I have tested it with my CVS install (ca. 4-5 days old) and it
>> works without problems.
>> 2. See my comments below:
>>> linux:/usr/localsrc/grass61cvs/extman/gem-1.0.rc5 # ./gem
>>> --install=/usr/localsrc/grass61cvs/cva/AdvancedViewshedAnalysis.tar.gz
>>> --grass=/usr/localsrc/grass61cvs/grass-6.1.cvs_src_snapshot_2006_06_18
>>> Uncompressing files...DONE.
>>> Checking extension...DONE.
>>> WARNING: GRASS version unknown. Extension might not work after
>>> installation.
>> this looks bad. Are you 100% sure that the path you have specified
>> with --grass= points to the install dir not the GRASS sources?
>> If it is the right path, then there must be a file etc/VERSIONNUMBER
>> which contains a single line reading:
>> 6.1.cvs
>> this is the version information for your GRASS installation and GEM
>> needs to be able to read this file.
>>> Configuring...DONE.
>>> Segmentation fault
>>> installation.
>>> Configuring...DONE.
>>> Segmentation fault
>> (same thing here, although I admit GEM crashes a bit ungracefully ...)
>> Make sure you have the right path.
>> Also, try to copy AdvancedViewshedAnalysis.tar.gz to the same
>> directory that GEM is installed in and install it from there.
>> If problems persist, I need a more detailed error log in order to
>> be able to help you.
>> Do:
>> ./gem --grass=[path] -vi [extension] &> log.txt
>> and email me 'log.txt'
>> Good luck,
>> Benjamin
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
