[GRASS-dev] error message for concurrent usage
Otto Dassau dassau at gdf-hannover.de
Fri Jun 30 06:03:52 EDT 2006
there is a wrong error message for concurrent usage. When user "otto" starts
GRASS in spearfish/PERMANENT and another user "stephan" tries to start GRASS
with the same mapset, following error message appears:
stephan is currently running GRASS in selected mapset. Concurrent use not
allowed.
it is confusing, because stephan is not the correct user. maybe the error
message should be more general:
another user is currently running GRASS in selected mapset. Concurrent use not
allowed.
 regards,
   Otto
