[GRASS5] v.digit odd attribute behavior
    Kirk R. Wythers
    kwythers at umn.edu
    Fri Mar  3 13:39:27 EST 2006
Radim,
I would like to hear your thoughts concerning what appears to be
fairly odd behavior in v.digit. First some background.
I am working with some vectors that were digitized by students using
ESRI products. The students then saved their work as shape files. I
am double checking their work and using v.digit (6.1.cvs) to make a
few edits (where my interpretation is a little different from theirs)
and add attributes to areas.
The vector is connected to a single table in postgresql.
In 90% of the cases were I select a centroid, or line, or an area,
the expected results get printed to for form which pop up.
However, in a few cases, when I select a centroid, the form pops up
with 3 tabs at the top (Layer 1, Layer 1, Layer2)
The two layer 1 tabs will different information in the fields
(including different cat values), and the layer 2 tab, says "Database
connection not defined"
g.list shows the vector name to be "test",
v.info shows 1 dblink. and the -c option shows:
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|id
CHARACTER|type
CHARACTER|class
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test layer=2
Displaying column types/names for database connection of layer 2:
ERROR: Database connection not defined
Any idea what might have happened? or how to get rid of the ghost
layer1?
Thanks,
Kirk
