[GRASS5] [bug #4138] (grass) nviz don't start from the GUI
Maciek Sieczka via RT grass-bugs at intevation.de
Mon Mar 6 16:53:04 EST 2006
Juan,
> Version: I downloaded "version 6.0 (stable) for fedora core 4", but
> in fact the rpm contains grass61 !
Where did you download it from exactly?
> Error description: nviz and d.nviz don't start properly from the user
> interface. It seems that the GUI call the command as if it has
> arguments, and so start directly nviz with no map information.
Using Grass 6.1 CVS 2006-02-20 for me nviz starts ok from d.m. But I confirm
d.nviz doesn't - it prints following error message to the terminal instead:
ERROR: Required parameter <input> not set:
    (Name of existing raster map).
ERROR: Required parameter <output> not set:
    (Name of output script).
ERROR: Required parameter <dist> not set:
    (Camera layback distance (in map units)).
ERROR: Required parameter <ht> not set:
    (Camera height above terrain).
ERROR: Required parameter <DEFANGED_frames> not set:
    (Number of frames).
Forwarding to Michael.
> I have solved the problem modifyng the file d.m.tcl
> (at /usr/lib/grass-6.1.cvs/etc/dm/)
> changing the calls to this command to term (instead of spawn)
> (at lines 671 and  679).
> Thanks
> Juan Carlos Torres
-------------------------------------------- Managed by Request Tracker
