[GRASS5] [bug #4142] (grass) sql statemts in d.m
Mon Mar 6 18:34:05 EST 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4142
> I may have found a bug in d.m. However, I may not be issuing the sql
> statement properly in d.m. For example If issue the following command
> on the command line:
> d.vect test fcolor=none where="type='JAPI'"
> the expected polygons are displayed.
> However, in d.m, if I type in the SQL where statement field:
> "type = 'JAPI'"
> which I believe is the same command minus the (where=) that worked on
> the command line, no vectors are displayed. Console output is as
> follows:
> d.vect map=test color=0:0:0 lcolor=0:0:0 fcolor=none display=shape
> type=point,line,boundary,centroid,area icon=basic/x size=5 layer=1
> lsize=8 xref=left yref=center llayer=1 {where="type = 'JAPI'"}
> Am I misusing the sql field in d.m, or should this be working?
Don't double quote the statement when run from the GUI
just:
type = 'JAPI'
Hamish
