[GRASS5] rasters?
Andrea Antonello andrea.antonello at gmail.com
Tue Mar 14 02:42:40 EST 2006
> I can only think of two changes:
> 1. For compressed maps (integer or FP), the size of the row offsets is
> sizeof(off_t) rather than sizeof(long). The main consequence of this
> is that 8-byte offsets will now be more common, so if your code only
> handles 4-byte offsets, it will fail more often.
I'm not completely sure but it should be that, which should again be easy to
solve (hopefully). I will check and in case come back with new questions.
Do you know when more or less sizeof(long) was changed.
Thanks for your help,
Andrea
____________________________________________________________________________
HydroloGIS - Environmental Safety Modelling
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile:  +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
